MANUAL PLANNING WHILST FLYING
(When using a Mini 2/Mavic Air 2/Air 2S)
In the Litchi App set the function button (KEYS) of the remote controller to ‘Waypoint at Aircraft’.
In Waypoint Mode tap the onscreen Mission Setting button and set:
-Heading Mode to ‘Custom(WD)’
-Finish Action
-Path Mode
-Cruising Speed
-Default Gimbal Pitch Mode to ‘Interpolate’
-Rotation Direction to ‘Managed’
Now fly your drone manually to a point of your interest (not a POI) and aim (frame) the camera.
Press the Function button to create a waypoint.
This waypoint will include the position and direction of the drone AND the camera’s pitch angle (Gimbal Pitch).
Fly to the next location and do the same (up to a maximum of 99 waypoints).
(The 99 waypoints limit will be remove in Litchi v4.24)
When there is an obstacle between any of 2 waypoints of your interest, you have to include waypoints whilst flying around it.
When you’re done flying, save this created mission and run (fly) it.
You may possibly have to fine tune it either on your phone or in the mission hub.
Like:
In Mission Settings:
-Finish Action
-Path Mode
-Cruising Speed
In Waypoint settings:
-Speed
-Curve Size
Advantages using this method:
-You can actually frame a subject realtime, no guessing of distance and camera angle.
-You are aware of any potential obstacles and deal with them.
-Most likely NO unexpected control signal loss trouble with VSC-drones.
