Hi
Is it possible to set waypoints during flight where the position of the gimbal is also recorded. I got it to work partially by setting C1 as the function key but I see that gimbal settings are not being registered. Is it a bug or is it not implemented yet?
Regards
Thomas
TriBar
July 26, 2022, 11:39am
2
Before you start recording a new mission make sure that in ‘Mission Settings’ you set:
‘Default Gimbal Pitch Mode’ to ‘Interpolate’.
Have a look at this topic:
MANUAL PLANNING WHILST FLYING
(When using a Mini 2/Mavic Air 2/Air 2S)
In the Litchi App set the function button (KEYS) of the remote controller to ‘Waypoint at Aircraft’.
In Waypoint Mode tap the onscreen Mission Setting button and set:
-Heading Mode to ‘Custom(WD)’
-Finish Action
-Path Mode
-Cruising Speed
-Default Gimbal Pitch Mode to ‘Interpolate’
-Rotation Direction to ‘Managed’
Now fly your drone manually to a point of your interest (not a POI) and aim (frame) the camera.
Press …
Does this allow the drone to fly the Waypoint mission while looking around with the camera?
TriBar
October 13, 2022, 7:43pm
4
Thanks for all the likes.
If you want to look around during any waypoint mission you have to set “Heading Mode” in “Mission Settings” to “Manual (UC)”.
I advise you to read the Online User Guide:
I keep reading and hopefully learning too. Thank you for having the persistence and patience to answer all the questions that you do!
