Custom functions are not yet implemented.
Change to AFS instead of AFC to prevent continuous autofocus
Hello, is it planned that the litchi app is compatible with the DJI LTE Dongle? It would be super useful for waypoint missions including areas where the drone connexion is bad.
No immediate plans for LTE dongle support, but of course it would be nice to have.
Noticed this myself. After running the DJI fly app the correct timestamps appear on the files again.
Setting AEB to 5 shots on the mini 3 results in 4 photos just being plain black, this saves on the drone and then also occurs in the DJI Fly app, and you must go back to Litchi Pilot to change it back to 3 shots, then it works fine again.
2 posts were merged into an existing topic: [OPEN BETA] Litchi Hub
5-shot AEB mode is not supported on this model (it is currently displayed due to an SDK bug). This setting will be removed in the next build for the Mini 3.
I have tried beta build 520 with a DJI Mini 2 (latest firmware).
- I was unable to find how to switch on camera view, it was only showing the map and the drone position
- On camera control it was showing “No SD card inserted” however the card was there
- Camera switch (photo/video) has actually worked, I was able to start/stop video and make photos with the button on the remote. In video mode the was even time running.
Am I missing something or it was just not implemented?
Yes:
Read the very first post in this thread.
Well, it’s not listed in the compatible list but not in “Unsupported” neither. As it was able to connect and actually control the drone I assume it is supposed to work.
Follow mode is also supported and would require a stream from camera.
So for me it’s unclear if it should work or not.
It clearly states:
“Litchi Pilot is compatible the following DRONES:”
So, all other DRONES are NOT supported.
When am I receiving the license error when I now try to launch the application ?
Are there plans to re-add the keys menu? I was wondering cause I have a DJI mini 3 pro. I want to set way-points at the drones location and I can’t find a way to do it.
I have an issue related to the latest version where I use DJI Mini 3 Basic and when using litchi flight beta it does not display any visuals at all from the drone camera in real time especially when using waypoint, but if I record in video mode then the visual display from the camera appears but when the recording is turned off then the visuals do not appear again, it is different from the com.flylitchi.litchipilot.dji_1.0.0_BETA-dji_430.apk version which is much more stable and has no problems at all especially in waypoint mode
i have another issues, because ver 1.0.0_beta-dji_500.apk dqpqt brings out the real time views of the Mini Basic camera so I used this version,But when running a waypoint mission, there is an obstacle where sometimes the real-time view display from the camera cannot appear, unlike version 1.0.0_beta-dji_420.apk which can display real time views from the Mini 3 Basic camera,not only that, even the 5 frame AEB mode doesn’t give the results that AEB mode should give,Many frames result in just blank black instead of photos taken with varying exposure results as AEB mode should work.
FORCE CLOSE any DJI app Before running Litchi Pilot.
and / or
Uninstall Litchi Pilot, then install it again.
Camera feed sometimes doesn’t work on Mini 3.
When it does work, switching mode (capture or record), capturing a photo, or start a recording freezes the camera feed again. Closing and reopening the app seem to fix it but freezes again when one of the mentioned action is done.
Im on the latest Build 526, and my phone is Poco X7 Pro
Edit: tested on build 514, the problem doesn’t appear to exist in this build
