Mavic Pro Platinum - Invalid Parameters at Waypoint
Hi all,
I’m trying to use a waypoint mission created from a previous flightlog flying a DJI Mavic Pro Platinum. The parameters set are photo intervals every 1m, altitude at 15m, cruising speed at 2.0m/s, and changes in heading direction at each waypoint. Each time I try to fly the mission, it loads to 100% at then says “invalid parameters at waypoint.” It does not tell me what parameters at what waypoints are invalid. I’ve tried tweaking small things and reuploading the mission numerous ways. Can anyone help?
Thank you.
I, too had a couple of short test missions that gave me the “invalid parameter at waypoint”.
I checked and re-checked the waypoint actions and settings, and have been unable to figure out the cause of the error.
All other missions (created using Mission Hub V1 or V2) have flown successfully on a Mavic 2 Pro or Air 2S.
Here’s one of the short missions that gave me the error message.
@Tiffany , if would like to share your mission, I’d like to have a look at it.
If you aren’t sure how to share a mission, here’s some information.
Most likely a corner radius at 1 or more waypoints too small (when Path Mode is set to Curved Turnes).
The range is:
Min-Max Corner radius of waypoint: 0,2-1000m (0.6-3280ft)
Here you can find more information:
Here is my flight mission: Litchi Hub
My path mode is set to straight lines since I’d like photos taken every 1 meter (which is not possible with curved turns)
The Mission you shared starts without a problem with my Mavic Pro (which is the same as the Mavic Pro Platinum, except for the motors and color) and Mavic 2 Pro.
Photo Interval works with Straight Lines missions as well as Curved Turns missions.
This brings me back to my first presumption:
Your erroneous mission was set to Curved Turnes AND you set the curves at waypoints to a smaller value than 0.2m (0.6ft), most likely to 0 (zero) thinking you then had a Straight Lines mission in order for Photo Interval to work.
We found the issue internally which I believe only affected the Litchi app on iOS. To fix a flight that wasn’t starting, simply modify it on the new Hub (any modification) to trigger a new save then it should work.
