[GUIDE] How to use Litchi Hub with DJI Fly
Many consumer DJI drones are not supported by the DJI SDK, which means they cannot be flown directly with our mobile flying app, Litchi Pilot.
However, you can still use our web planner, Litchi Hub, to plan your flights and then export them to DJI Fly / SkyRover to fly them. The only requirement is that your drone supports Waypoint mode in its official app.
The following drone models support this:
  • Avata 360
  • Lito X1
  • Mini 5 Pro
  • Mini 4 Pro (also has native DJI SDK support so you can fly with Litchi Pilot too)
  • Air 3 & Air 3S
  • Mavic 3, Mavic 3 Classic & Mavic 3 Pro
  • Mavic 4 Pro
  • SkyRover X1 (using SkyRover app instead of DJI Fly)
Step-by-Step Guide
1. Plan your flight in Litchi Hub
Head to https://hub.flylitchi.com/ and open the Flight Library (blue folder button in bottom left corner). Then click on “+” and “New Flight” to create your waypoint flight making sure to select your supported drone model and DJI Fly app in the prompt.
You can then starting planning your flight within Litchi Hub and continue this guide when you’re ready to export.
2. Create a waypoint flight in DJI Fly (optional for iPhone/iPad)
  1. Open the DJI Fly app (drone connection not required)
  2. Enter the Camera View then tap on the Exter/Exit Waypoint Mode button
  3. Place 2 waypoints on the map, preferably near the same location as the Litchi Hub flight
  4. Tap on the Exter/Exit Waypoint Mode button, then tap “Save and Exit” in the popup.
3. Export Litchi Hub flight to DJI Fly
In Litchi Hub, open the flight settings and click the blue Export button.
Some browsers (Chrome and others) will ask you to grant the ‘Apps on device’ permission to Litchi Hub. This permission is required for Smart DJI Fly Export so make sure to allow it.
A. Smart Export using Litchi Hub Bridge (recommended)
  1. Download, install and start Litchi Hub Bridge. Litchi Hub Bridge is a companion app designed to run in the background and lives in the system tray/menu bar. It includes a simple settings interface but otherwise requires no user interaction.
  1. Connect your device that runs DJI Fly (phone/tablet or the DJI RC if it has a display), unlock it, then select File Transfer USB mode on Android or tap Trust This Computer on iOS. You should then see your DJI Fly waypoint flights listed
  2. Select the flight to replace and click the “OVERWRITE” button. iPhone/iPad users can also chose to create a new DJI Fly flight instead of overwriting an existing one.
  3. The created or replaced flight will show the new Litchi thumbnail and updated status.
B. Manual Export Alternative
  1. Click Download KMZ in the DJI Fly Export popup
  2. Locate and replace the DJI Fly KMZ File
  • Using a file explorer, connect your device in File Transfer USB mode and go to:
Android: Android/data/dji.go.v5/files/waypoint
iOS:     DJI Fly/wayline_mission
  • Locate the latest folder that was created in the above location, then inside you will find the KMZ file created by DJI Fly.
  • Rename the KMZ file exported by Litchi Hub to the same name as the KMZ created by DJI Fly. Then replace the DJI KMZ with the Litchi Hub KMZ
4. Load the Flight in DJI Fly
If you now go back to the DJI Fly app, you will be able to load the flight planned in Litchi Hub!
For iPhone/iPad users, if you created a new flight, make sure to restart DJI Fly to see the new flight.
Importing Litichi KMZ to DJI Fly App
[OPEN BETA] Litchi Pilot
Supported Drone Models
[OPEN BETA] Litchi Hub
Litchi on new drones
Way point placements, Camera changes on litchihub, restarting a mission
Mini 4 Pro, RC2 for Mission Planning - Options
Mini 5 Pro support ?
Dji mini 4 pro waypoint
Litchi with RC2
Workflow No Longer Working to Run Waypoints / Area Mapping with RC2 and DJI Mini5 Pro
Connection problem DJI Air 3 + DJI RC 2 + Litchi Hub
Mavic 3 Classic
Export to KMZ file dissappeared in past week
No License Found for Beta - Basic IOS Question
Issue with mission export on new hub
Can I use Litchi Pilot with the DJI Mini 4 Pro?
Entire Workflow on a IPad (IOS)?
Can't Export File for use in Mini 5 Pro
Does Litchi For DJI Drones work with Mini 4 Pro?
Skyrover X1 (DJI Mini 4 Pro clone)
Litchi Pilot & Skyrover X1 Waypoints Flight
Inquiry Regarding Droneception Feature on DJI Mini 5 Pro
A question about adding waypoint files to the X1 screen controller from Litchi Hub created .KMZ files from PC? or Android phone?
Rc rm 330 e mavic 3 class
Litchi Bridge not picking up my controller
Updated Litchi app for the new DJI Lito 1
Skyrover X1 with screen controller
Will the Litchi work with DJI Lito 1 / X1?
LITCHI on DJI RC Pro 2 Controller - Air3S/Air3
DJI Air 3S – How does splitting a 3D mapping mission into multiple flights work?
Uploading to rc 2
Is it possible to offset active track focus? (DJI Air 3S)
Mavic Pro 3 waypoints... any way to transfer the DJI remote waypoints to Litchi?
Moving KMZ files to an RC Pro 2
Installing Litchi on the DJI Smart Controller
Litchi Bridge Request NOT to overwrite waypoint images
Problems with Smart-DJI Fly Export
Mini 5 Pro, RC-N3 support
Is MAC OS incompatible with Litchi transfers to DJI RC controller?
Cant load waypoint mission into the RC2
Litchi example .csv
Availability mini 5 pro
Device not connected
Litchi on Macbook Air for Mini 4 Pro
Why not Mini 4 Pro? Should work the same.
You could use this procedure with the Mini 4 Pro, but the Mini 4 Pro is already supported in the MSDK so you don’t need to go through this procedure.
Would that not equate to acquiring Litchi Pilot, and pay for the software all over again? I don’t have Litchi Pilot since I never had a Mini 3 series drone.
Yes, directly flying a Litchi mission with a Mini 4 Pro would require that you use the new Litchi Pilot app. If I’m not mistake, it is currently freely available since it is still in beta.
I downloaded a kmz file from hub 2.0 and used this technique to run a waypoint mission on my Air 3s. It flew a straight line mission without the usual rounding added by DJI. The drone also stopped at each waypoint. Is this the expected behavior?
I have previously used this technique with kmz files produced by Litchi mission utilities and a Hub 1.0 csv file. Those waypoint missions had the typical DJI rounding.
It is if your path mode is set to straight lines. If you sent the path mode to “Smooth Curves”, you should get your expected behavior:
Capture
Thanks for the quick reply! I did have “path mode” set to “straight” because when I set the path mode to “curved turns”, the export dialogue replied “kmz export does not support curved turns flight mode”. I had set the “drone model” to “other” and “Smooth Curves” was not an option so I used curved turns. When I set “drone model” to Air 3S, the “smooth curves” option was available. I was then able to download the kmz file!
What is the difference between smooth and curved turns?
By the way, the “straight lines” option eliminated the danger of the drone descending lower than the waypoint!
You should see the difference when selecting between the two with an appropriate drone model. “Curved” is used by the Litchi engine where “Smooth” is used by the DJI engine.
I have encountered the same problem. Since I use DJI fly I have to export to kmz but it does not allow me to export the routes with “curves” at the waypoints, but only those with “soft curves” or “straight lines”. However, with the old cvs to kmz conversion system it accepted the “curves” at the waypoints and even in DJI fly you could see the track with the curves. Soft curves are difficult to control because the route can drop too much in altitude or widen too much where it shouldn’t.
You will need to explain what you mean by “soft curves” as that term is not used by either Litchi or DJI.
DJI Fly waypoints only support curved paths that pass through each waypoint. As a result, it is possible for the flight path to become lower (or higher) than an adjacent waypoint. It is also possible for DJI Fly to fly a straight line mission. However, such a mission must be loaded via a KMZ file as there is no way to select the path mode from within DJI Fly.
Sorry “Smooth Curves”..
Ok. I understand now. What Litchi is calling “Smooth Curves” is referring to DJI’s method of making the flight path pass through each waypiont. Litchi’s method places a straight flight path between each pair of waypoints with the option to use curves at the locations of the waypoints.
Each method has their advantages and disadvantages. As you point out, DJI’s method may allow the flight path to become lower (or higher) than any of the waypoints used to create the path.
As DJI does not support Litchi’s style of curved flights, one cannot export that kind of path into a DJI KMZ file. Your only choices will be either straight lines or smooth curves.
When downloading the kmz (dji fly) from https://hub.flylitchi.com/ and uploading it to the dji fly app, the mission does not load, it just appears blank.
Welcome to the forum.
More details are needed. This process does work as many are doing it. Did you replace an existing kmz file using the same name?
Yes, it was actually working without any problem before, but now the planned flight simply won’t load, I will continue testing to find out what the error is.
I’m flying a DJI Air 3S and have created a waypoint mission in Litichi Hub. I have tried and tried to import it into the DJI RC2 controller with no luck. I Rename the KMZ file exported by the Litchi Hub to the same name as the KMZ created by DJI Fly. Then replace the DJI KMZ with the Litchi Hub KMZ. When I go back into the waypoint missions on the controller it’s not there. The mission I created with 2 waypoints is still there. Could anyone please explain to me why this is happening? I’ve done it 10 times with the same results. Thanks guys!
I’m sorry to hear that. It can seem like a tedious process, but I work with people who do it all the time. So, I know the process does work.
That is the correct process (at least part of it).
This suggests a couple things. Either you are not copying the newly created mission over the existing mission OR you are copying the newly created mission over the wrong mission.
Assuming you know how to copy and replace files in the Android system, what you describe suggests that you are not replacing the mission you think you are replacing. What some people do is you create a new “dummy” mission in DJI Fly knowing that you are going to immediately replace it. This way, the new “dummy” mission will have the most recent modification date/time. Then, when looking at the missions through the Android file system, it is easy to sort the mission folders by date to see the mission folder with the latest modification time and replace the KMZ file within it with the new KMZ file.
If you have several missions in DJI Fly, load each of them one-by-one to see if you recognize the mission you created in Litchi’s Mission Hub (v2). This will tell you if you copied your new mission into the wrong folder.
Also, if you export the KMZ file that you imported into DJI Fly and send it to me, I can tell you whether it orginated in DJI Fly or Litchi’s Mission Hub (v2).
When I export the file out of Litchi, should it be kmz or csv? I’ve tried to export as csv and it says coming soon then use the converter to convert it to kmz?
You export the mission as a KMZ file.
Converter? You just save as a KMZ file from the Mission Hub v2.
