waypoint and dji 4 pro
Is using the litchi waypoint function 100% reliable with the dji4 pro drone (I don’t want to lose my drone) ?
It is as reliable as the DJI waypoint function. Provided that you place the waypoints so that the path does not pass through an obstacle, you shouldn’t have a problem. I have been using Litchi since 2017 and never had an issue. Is there a specific thing you are concerned about?
Thank you.
How do you export the flights you create to the RC2 transmitter ?
How do you manage the exported flights on the RC2? Can you have multiple flights ?
@vico already gave you a link to a tutorial in your other post “Litchi with RC2”:
In the Hub and on your RC2.
As described on page 40 of your drone’s User Manual.
Yes, as many as you want.
(a “dji 4 pro” doesn’t exist, You either have a Mavic 4 Pro or a Mini 4 Pro).
Is it possible to import multiple missions at the same time on DJI Fly?
Yes. If you want to import four mission, first create four dummy missions so that each one can be replaced. Some of your questions can be answered yourself by just giving it a try.
Sure he does. I think he means a Phantom 4 Pro
