I would like to create a mission to follow waypoints to get to an area where I would like to Obit a POI and then follow waypoints back home. Can this be done ?
TriBar
August 27, 2022, 6:25pm
2
You can not include an Orbit in a waypoint mission
Have a look at this topic for a possible solution:
It allows you to specify the starting, ending, and POI height then generates a path and gimbal pitch angles based on those (and other) parameters making a perfect circle, spiral, or coil in a waypoint mission.
General workflow :
Use Google Earth Pro to define a perfectly circular path around the POI.
Export that path as a kml file.
Import that circular path into my web application and specify heights and other parameters.
Export the path as a csv file.
Import that csv file into the Litchi Mis…
