hi freinds , i have mini 2 when i connect with my 15 pro max i can see only map or blank screen in my phone how to enable camera view in my phone screen ? can any one help pleasee
When I had this same problem some time ago the solution turned out to be replacing the generic cable connecting my iPad to the drone controller with a genuine Apple cable. Another time I encountered this problem, the solution was replacing the drone’s SD card with a better quality SD card. These two possible solutions are affordable and easily tried, so I would suggest you carry out these two steps and see if they work.
thank you brother will try with original cable
What is the exact model of your drone? If you really have a Mini 2, it should work. However, your description of the problem suggests you have a Mini 2 SE, which is not supported.
I have adjusted the subject of this thread to be appropriately sized and moved to the correct category.
