Not familiar with the F mode you speak off. Unless it’s the same as the Fn Key I mentioned ,in an earlier post, that you’ll find on most laptop and on some wireless keyboards.
Yeah, you were on the right track.
I avoid the laptop keypad, mostly the mouse touch pad. I had a laptop once that had the eraser stick in the keyboard, that was better to me.
Both the Dell Laptop W10, Desktop Win7 is using a Wireless Keyboard and a rodent (mouse).
Rod…
The F11 thing was a user error, I thank all for helping on that!
But all this started because the font size and dim text in the waypoint window, especially the ground level.
How do you adjust that on a computer browser?
Rod…
@Rod_Pad If I remember correctly, as you make the “Waypoint Settings” window larger (like in your bottom screenshot) then the waypoint altitude numbers also get larger. When you shrink the Waypoint Settings window, it also shrinks the altitude numbers for your waypoints. I found this to be irritating because I wanted to make the Waypoint Window smaller but found it difficult to read the waypoint altitude numbers. So I compromised and made the adjustment halfway. There is no way to only adjust the waypoint altitude numbers by themselves in order to make them larger and easier to read that I know of.
OMG!
Thanks man this is what has been F* me for a long time.
I guess there is no way to change the waypoint window size?
The Mission Hub screen is in control no matter what browser your using?
Thanks again!
I’m still shocked that Litchi does what it can do and its a one time fee?
I think it is assume!
If anybody wants to look into this, give us an update!
I used dos, and remember when MS came out with Windows.
I had to buy a rodent (mouse) $60.00 with the serial card, ETC!
Anyways, I will look for some HTML people. A program language that I didn’t want to learn.
Rod …
Well this friend would give me an answer or tell me what to try to get there.
Hi,
That is controlled on the server side so not much you can do. There is a setting in windows where you can change the font size but this will change it for everything not just the browser.
Tony
Anyways, this problem I have is nothing a can fix myself no wonder I keep giving up.
I have messed with Laptop W10 settings, I will try again later.
Geese
I still think the Litchi price is to cheap for what it does.
I will be back, unless I expire.
Rod…
What is funny, I had this feeling I was going to waste my time and others. Then not find a fix.
I’m I stupid, is there like a Mission hub wish list, that I could of searched?
My friend that gave me the answer, I know I bugged him some time ago, he couldn’t see the ground elevation, because he didn’t have an account.
I’m not dumb yet!
Rod…
