Record a flight path while flying manually?
I have a construction site that I need to get a really precise video of that I can repeat weekly. So I’d like to manually fly the route a few times to get it right, then once I’m comfortable with it record that route and save it so I can re-fly the same route.
There may be some gimbal angle changes.
How do I record this route and any camera changes with Litchi? (IOS, Mavic 2 Pro)
Thanks!
Obtain the log file of a flight (using AirData is the easiest way) then use my “AirData to Litchi” converter.
… or use this method:
Thanks to both of you! I’ll give both those methods a try. I’ll be using the function button method to setup a recurring photo flight or two, but thought it might be a bit awkward to do it why also trying to get a video. Sounds like it’ll just take some tweaking in mission hub to make it look like a single smooth video, but probably doable.
Thanks again!
