Salve, vorrei sapere se LITCHI permette di CALIBRARE l’IMU del DJI MINI 2, non ho trovato alcuna possibilità di farlo tramite l’App, esiste solo la possibilità di calibrare la Bussola, ma non l’IMU. Potete aiutarmi a capire?
Hi, I would like to know if LITCHI allows you to CALIBRATE the IMU of the DJI MINI 2, I have not found any possibility to do it through the App, there is only the possibility of calibrating the Compass, but not the IMU. Can you help me understand?
The problem is that the DJI FLY APP doesn’t work for me, otherwise I wouldn’t have used LITCHI APP. In this case, are there any updates for LITCHI so that IMU calibration can also be performed?
The Litchi app should not be considered a replacement for the DJI app. Instead, it extends the capability of your drone. There are other posts here that list the functions that are only provided by he DJI app.
I do not know the answer to that but Litchi is limited to provide what DJI enables in their SDK. My guess is that DJI does not provide an IMU calibration interface. Just a guess.
