Hello everyone,
I own a DJI Matrice 4T and would like to use it for construction monitoring.
I wanted to create a circular flight with a fixed gimbal tilt to a POI.
There’s a suitable function in the Pilot 2 app for this. However, it’s not perfectly reproducible, as the recordings will also be used for a time-lapse over several months.
After testing Litchi Hub, I discovered the orbit function and found it very useful. Unfortunately, transferring it as a kml file to the remote control doesn’t work flawlessly.
The flight altitudes are changed, the drone yaws along the flight path and not toward the POI, the gimbal isn’t pointing toward the POI, and no images are being taken.
Is there a suggested solution?
Best regards,
Marcus
