- to our knowledge the only limit is how powerful your phone or tablet is, I very much doubt there is a limit of 450 waypoints in DJI Fly
- probably keep track of the waypoint number on the DJI Fly display is your best bet. We cannot add features such as auto resume to DJI Fly, for that you’ll have to use Litchi Pilot and a compatible drone model among the ones listed here: [OPEN BETA] Litchi Pilot
- please share a link to the flight so we can diagnose the issue (guide to share a flight: [GUIDE] How to Share a Flight or Folder)
- added to our backlog
- Should not cause any issues
- strange issue, have you tried to disable obstacle avoidance? the gimbal should stay at -90 all the time when in 2d mapping mode
- you can always check the flight path in 3d or google earth map view, that will answer your question directly. we have tried to make sure this issue is minimized
- if you transferred the flight, then they’re already overwriten therefore you don’t need to do it again in the field
- Open the flight library, then you can see all your flights on the map displayed with blue map markers, click on a marker to open each flight. Only one flight can be open at once.
- Should work in theory but I don’t live in USA nor do I have a M4P so cannot confirm.
