- Configure Parameters
- Draw the polygon
- Download Litchi CVS
Is hosted in GitHub https://afbayonac.github.io/grid-photogrammetry/
Hi!
Well, what can I say, not bad, not bad for a start!
But not very many people bring it to the end, and it’s a pity …
Because there are many opportunities in this program, if you implement them.
I wish you good luck, with uv. Magomed.
Do you have the opportunity to add such functions?
Thank you very much for your work, and I hope for your feedback and understanding of the pilots’ wishes!
Hi. Your tool looks great. Unfortunately I cannot download the file. Any idea what could be causing this?
Greets Chris
Hi!
This is not a program yet, but just a web application.
You might want to correct the spelling errors in your program:
“Lichit” should be “Litchi”.
“CVS” should be “CSV”.
Fix thanks
Clear the cache!
Thanks.
I have a error, now is fixed.
Try again.
Clear the cache!
Bonjour, quelle serait la meilleure configuration à utiliser pour un Mini 2 ? Ce n’est pas la même chose que AIR 2 S.
Merci d’avance et belle initiative.
Not, you should look for the correct parameters for the drone, if you have these, I can add them to the list
Merci, très intéressant.
Friend! If you have a desire to improve and modify your application at least a little, I would advise you to pay attention to these points.
With your permission, I have slightly corrected the database of drone models.
export default [
sensorWidth: 6.3,
sensorHeight: 4.7,
focalLength: 4.9,
imageWidth: 4056,
imageHeight: 3040
name: 'DJI Air 2',
sensorWidth: 6.4,
sensorHeight: 4.2,
focalLength: 4.49,
imageWidth: 8000,
imageHeight: 6000
name: 'DJI Mavic Mini',
sensorWidth: 6.3,
sensorHeight: 4.7,
focalLength: 4.49,
imageWidth: 4000,
imageHeight: 3000
name: 'DJI Mini 2',
sensorWidth: 6.3,
sensorHeight: 4.7,
focalLength: 4.49,
imageWidth: 4000,
imageHeight: 3000
name: 'DJI Mini SE',
sensorWidth: 6.3,
sensorHeight: 4.7,
focalLength: 4.49,
imageWidth: 4000,
imageHeight: 3000
name: 'DJI Mavic AIR 2',
sensorWidth: 6.4,
sensorHeight: 4.8,
focalLength: 4.49,
imageWidth: 8000,
imageHeight: 6000
name: 'DJI Mavic Air 2S',
sensorWidth: 13.2,
sensorHeight: 8.8,
focalLength: 8.4,
imageWidth: 5472,
imageHeight: 3648
name: 'DJI Mavic 2 Zoom',
sensorWidth: 6.3,
sensorHeight: 4.7,
focalLength: 8.6,
imageWidth: 4000,
imageHeight: 3000
name: 'DJI Mavic 2 Pro',
sensorWidth: 13.8,
sensorHeight: 8.8,
focalLength: 10.3,
imageWidth: 5472,
imageHeight: 3648
name: 'DJI Phantom 3',
sensorWidth: 6.3,
sensorHeight: 4.7,
focalLength: 3.61,
imageWidth: 4000,
imageHeight: 3000
name: 'DJI Phantom 4',
sensorWidth: 6.3,
sensorHeight: 4.7,
focalLength: 3.61,
imageWidth: 4000,
imageHeight: 3000
name: 'DJI Phantom 4 Pro / 2.0 / Advanced',
sensorWidth: 13.2,
sensorHeight: 8.8,
focalLength: 8.8,
imageWidth: 5472,
imageHeight: 3648
Add, thanks
Clear the cache!
I will work on it. but no promises
Thanks! No problems.
How does it know the flight speed and photo interval to estimate photos?
