No matter if I use my iPhone or iPad I can’t activate “FOLLOW ME” mode because of no GPU???
I’m sure you mean no GPS.
FOLLOW ME makes use of the GPS coördinates of the device (phone or tablet).
In case you use your iPhone, make sure to turn ON location services.
In case you use your iPad, iPads without cellular do NOT have a build in GPS receiver and therefore will NOT work with FOLLOW ME.
Yes I meant to say GPS, I have an iPhone 11 and a iPad mini 4 and both DON’T work with follow me. I don’t understand (location services)
OK I just checked my phone and ALL location services is turned on.
Can you post a screenshot with the error message and a screenshot with Follow Mode selected.
Well, that’s NOT what you wrote in your first post.
Go outside to aquire more satelites until the text “Accuracy: 17m” in the lower left corner of the screen turns green, the number has to be 10m or less.
and read the Online User Guide, and read the thread mentioned below.
Thanks for trying to help but it’s just too annoying to have to deal with. I rather just push a button and have the drone follow me anywhere like the new DJI Neo. Litchi was a TOTAL WAIST OF MONEYS…
In order for the drone to do something when you push a button, there has to be some technology behind that button. In this case, that technology is GPS. To make use of GPS, both you and your drone must be outside where your phone and your drone have an unobstructed view of the sky. Then, there should be sufficient positioning accuracy for “Follow” mode to work.
