Curved transitions for Mavic 4 Pro?
Hello,
I’ve done hours and hours of research on this and learned a lot. Unfortunately a lot of the information I’ve found has proven to be false and I’m at a loss. The best info I have found has been on these forums, so I’m hoping a Litchi expert can get me a final answer.
I’m using the Mavic 4 Pro with RC2 controller. I need to be able to create waypoint flights with curved transitions from point to point. Through the Litchi beta hub I was finally able to export a file that I can transfer to the RC2, but it won’t allow curved transitions, resulting in video that isn’t smooth with an obvious “hitch” at every waypoint.
I really love the Litchi hub, and I realize the compatibility issues with DJI’s implementation of WPML. So, is there any way to create curved flight paths in Litchi that will work with DJI Fly?
Thanks in advance!
First, we have to establish correct terminology. There is no such thing as “curved transitions”. The global setting that are available include:
  1. Path Mode: Smooth Curves, Curved Turns, Straight
  2. Heading Mode: Follow Path, Transition, Locked, etc.
I’m guessing that what you want is the “Smooth Curves” path mode. You probably also want to use the “Transition” heading mode. These should both be available (and supported) in all DJI Fly drones with native waypoints.
Capture
After selecting those and transferring the mission to a Mavic 4 Pro, if you are experiencing something other than smooth curves and linear heading transitions from one waypoint to the next, respond here with a description of your flight.
Thanks for the quick response. That appears to be an option I don’t have. See the first screen shot below.
I went ahead and included the second below to show what happens when I try to export files with curved turns.
You have NOT selected a Drone Model.
The options change after you select the drone model. Always select the drone model before doing anything else.
I’ve never been more happy to feel dumb! Thanks for the assist.
A post was split to a new topic: Waypoint mission problem after exporting to RC Pro 2
It definitely sounds like the export settings might be defaulting to a straight path mode during the conversion. Have you double-checked that ‘Smooth Curves’ is explicitly selected in the Litchi Hub before generating the WPML file? Sometimes the RC2 requires that specific configuration in the mission settings to avoid those hitches during playback.
This has already been resolved. He wasn’t selecting the drone model before designing the mission.
The issue was not specific to the RC2. He wanted “Smooth Curves” but only “Straight Lines” was available because he had not selected the drone model.
