I’m pretty new to Litchi, so my apologies if this is something that can already be done while in flight – I spend more time in front of the PC than I do behind the sticks and I notice that some features/settings are only available when connected to the drone.
When creating a mission from your phone, is there a way to fly the drone to a target location, push a button, and create/add a waypoint with all the pertinent information (orientation, altitude, coordinates, gimbal pitch, etc) based on where the drone is at that point in time?
I suppose the alternative workflow would be to fly to a target location, add a waypoint and drag it precisely over the drone’s current location, and then note all the relevant information to update the waypoint accordingly.
Hi TriBar, i tried to follow your instructions and doennt work
-Finish Action- i put -None-
-Path Mode- i put -Straight Lines-
i set up my FN button in waypoint keys to -Waypoint at Aircraft-
i took off manually in waypoint mode and when i hit the FN button nothing happened
can you help ,thanks
Hello.
I want to reopen the Thread, even nearly a year old.
As for the Mini SE there are no funktion-Keys:
Is there an other possibility to store the current position as a waypoint / POI ?
Thanks in advance.
