Air 2s gimbal settings
Hi
Is it possible to set waypoints during flight where the position of the gimbal is also recorded. I got it to work partially by setting C1 as the function key but I see that gimbal settings are not being registered. Is it a bug or is it not implemented yet?
Regards
Thomas
Before you start recording a new mission make sure that in ā€˜Mission Settings’ you set:
ā€˜Default Gimbal Pitch Mode’ to ā€˜Interpolate’.
Have a look at this topic:
Does this allow the drone to fly the Waypoint mission while looking around with the camera?
Thanks for all the likes.
If you want to look around during any waypoint mission you have to set ā€œHeading Modeā€ in ā€œMission Settingsā€ to ā€œManual (UC)ā€.
I advise you to read the Online User Guide:
I keep reading and hopefully learning too. Thank you for having the persistence and patience to answer all the questions that you do!
