now as I own a Mini 2 which has the capability to zoom the camera, I am missing this function in Litchi.
In Rainbow and DJI Fly it is existent, but I wonder, why it is not existent in Litchi.
I believe, zooming is available on the controller (I maybe wrong!), is there a reason, why Litchi got no slider on the screen? Or did I miss something?
The Mini 2 spec says, the Mini 2 got 2x zoom in its camera and this is working with Func + wheel. Rainbow additionally can do 4x zoom, however, this is only optical on the mobile and you can not record this. For the mini 2 you should be able to record 2x zoom in video mode, and, as far as I read (but here I might be wrong) 4x zoom in picture mode - all natively. However, it is not made clear by DJI if they do it in hardware or in its software.
Oh, understood! You meant the search magnifying glass! Yes, that is well known. I thought, you meant some icon in form of a magnifying glass, which got the function of zooming.
Itâs not entirely clear what you mean by that. When referring to digital cameras, there are traditionally two types of zooms:
Optical zoom
Digital zoom
Unfortunately, DJI has often mis-used the term âZoomâ in their literature confusing a lot of people.
An optical zoom lens uses a complex system of movable components to alter the focal length and angle of view with no trade-off in quality when âzoomingâ.
A digital zoom simply uses a scaling algorithm to simulate what a true optical zoom lens does. The same thing can be accomplished in post-production. In this case, âzooming inâ is just scaling the image.
The only DJI drone with a true optical zoom is/was the Mavic 2 Zoom. All other DJI drones that are claimed to have a zoom lens employ a digital zoom. For example, the new Mavic 3, despite DJI saying that it has a zoom lens, really has two fixed focal length lenses (one wide-angle and one telephoto) and uses digital zooming to transition between the two.
And I would like to add to that, âscaling upâ is typically referred to as âcroppingâ in post-processing SW⌠Thanks for your very clear explanation!
