now it is going higher as the elevation and lower as it elevation decreases i,ve always beem able to pick an elevation at number 1 waypoint and it kept it the same thurout the flight if I checked above ground , lately it runs into the ground or soaes up way to high What gave i missed or forgot
That is what the above ground option is supposed to do — maintain a constant height above the terrain.
You will need to select the desired height above ground at each waypoint. You will also need to make sure the “above ground” option is selected at every waypoint.
Punctuation.
Some of these replies hurt my brain! Please people read what you have typed before you hit “SEND”
