Waypoint/POI failing when going to lounge
Good day to all
Im look for some help with Litchi.
I plan out my waypoints and point of interests
but when i load it to start to fly , as soon as i click on go i’m getting the message:
Fail to load mission. who can help me with this issue?
i’m using a DJI phantom 3 standard with the newest firmware for this drone
The “Failed to Load Mission” error message often means there might have been a procedural error in the Litchi Mission Hub flight plan that was created and saved. Litchi does impose a limitation on how far apart waypoints can be, and there is also a limitation to how close together waypoints can be.
I don’t recall the range of waypoint separation distances that are permissible in Litchi flight plan creation, but it should be possible to find that information in the Litchi online user manual.
If you forgot to select the GPS-referenced “P” position of the mode selector switch on your drone’s controller, the Litchi mission will not start and that could also generate a “Failed to Load Mission” error message.
By the way your museum piece Phantom 3 Standard is a superb model for deploying on fully autonomous Litchi waypoint missions. Lighter in weight than the other costlier Phantom 3 models namely the Professional, The Advanced, and the Phantom 3-4K, the Phantom 3 Standard, with its Litchi mission cruise speed set at 27mph, will traverse round trip distances nearing 7 miles, provided of course that BVLOS flying is allowed where you reside. I should know these facts because I own two Phantom 3 Standards and one Phantom 3 Professional.
I found this information etched in stone where I often venture to seek wisdom atop a frozen mountain peak amid the swirling mist. " The 3D distance between consecutive waypoints must be between 0.6m and 1999m .
Make sure the “S1” switch on the controller is in position 3 (toward you).
Capture
