Hi there, used my DJI Mini 2 with the Litchi App yesterday for the 1st time (ios). Had planned a test mission following waypoints that seemed to work fine in terms of folowing the route. The camerawork was a little jerky but thats mentioned elsewhere. My big issues was that, upon reviwing the footage it seems the mission failed to do all of the actions that I had plotted for various way points - such as stopping recording, taking photos etc.
Anyone else had issues with this? Is it a problem with the app or user error (most likely ;-))
Actions do not work because the app does not know when to trigger the actions because the turn is curved. It might be reworked in future versions in the app where it would calculate the middle of the turn and do it there, but I don’t know if Litchi developers will work on this. Anyway, if you want your actions to work, then set turns to Straight in Mission Settings, then your drone will stop at each waypoint and follow the actions.
My AIR 2s waypoint mission today.
Flew route correctly, but, also had issues with “actions” not working.
I had WP3 as the actual start of mission, had straight line route with the actions to “HOLD”, “TAKE PHOTO”, “START RECORD”. It held but no photo, and no start record. Then the curved route starts at WP4.
So do you need a mission with NO CURVES at all, to get the actions to work correctly?
It’s pretty simple. Video needs smooth lines. For photos, straight lines. Any mission can be completed two or three times with different settings and get a good result.
My mission does not have any curved lines (I’m assuming this is done by selecting all the waypoints and setting the curved paramater to 0m?). The mission itself contains 140 waypoints, each of them with the actions: stay for 3s, tilt camera, take photo, stay for 3s. The actions are performed perfectly on the first waypoint, but then the drone (DJI mini 2) continues flying throught the entire waypoints without performing any actions…
