how do i transfer waypoint missions recorded in air on smart controller to my laptop running windows 11
Assuming you are talking about waypoint missions created with the Litchi app/hub, you can find them in these locations:
LITCHI Missions (Android version):
“\Phone\Android\data\com.aryuthere.visionplus\files\missions\__users\[8-character-token]\”
LITCHI Pois:
“\Phone\Android\data\com.aryuthere.visionplus\files\pois”
LITCHI Missions (Amazon version):
“\Phone\Android\data\com.flylitchi.litchi.amazon\files\missions\__users\[8-character-token]\”
LITCHI Pois:
“\Phone\Android\data\com.flylitchi.litchi.amazon\files\pois”
There’s no difference between waypoint missions created by what ever method used.
Your question is unclear.
The normal procedure used for transferring missions either way between Litchi’s Mission Hub (which could be running under Windows 11) and the Litchi app on your Smart Controller, is to simply sync your mission(s). If you have created a mission on the Smart Controller, make sure your Smart Controller is connected to the internet and that the “Sync local missions” is selected in Litchi settings. Syncing should then occur automatically. Then, open Litchi’s Mission Hub on your Windows computer and choose “Open” to open the synced missions. Obviously, you will need to be logged into both of these applications using your Litchi credentials for syncing to work.
If you are trying to do something different, please provide more details.
Thanks all synced now
