If I have two waypoints that are set on either side of a hill/mountain and am using the “above ground” feature correctly, will the drone fly path 1 or 2? Both WP2 and WP1 are set at 200ft above ground.
Bonjour,
Le drone suivra le trajet 1. Donc il percutera la colline.
That configuration will cause your drone to crash into the side of the hill. The height above ground is only determined at the waypoints. You would need to add at least one waypoint to the top of the hill. More details can be found here:
