Waypoint litchi pilot
Why when I start waypoint on litchi pilot on dji mini 3, I get error cannot start there is a warning “Flight Interrupted: The flight mode was changed” even though I did not change any settings. is there a solution? Thank You
Make sure you have the controller set to “Normal” mode.
The remote is in normal mode and has never been replaced, but an error like that still appears, why is that?
Another thing that may cause that error to occur is if you try to start a waypoint flight in an “Enhanced Warning Zone”. Verify that the mission is not in such a zone.
First, you would need to confirm that you are in such a zone. If you are, you would need to unlock that zone using the DJI app. Once the unlock code has been loaded into the drone, you can take off and fly the mission using Litchi.
