flying a mission and I have set the altitude at 350 ft. I checked the box that says ”above ground level”.
I am starting from a high point and dont want to find later that i was flying over 400’ AGL over some of the lower areas but at the same time want to be clear of the powerlines.
There are (2) numbers next to each waypoint, one is the 350 number, what is the other one? As long as the waypoint altitude stays a 350 , i assume that i am always 350 above the changing ground level- correct or is there more to it?
Thanks
