Unstable hovering during waypoint flight
I’m preparing to photograph the nightscape from an altitude of approximately 150m.
Since it will be a night flight, I’m trying to automate it using the WayPoint function.
During a test flight in the day, I found that my air craft (Air2s) became extremely unstable during the hovering time set during the WayPoint flight.
Initially, I thought this was due to the wind, but the unsteady behavior occurred even on calm days. Furthermore, the instability persisted even after deleting the POI where I was shooting. I then found that stopping or canceling the WayPoint flight stabilized the aircraft.
As a workaround, I will stop the WayPoint flight and continue shooting, but I believe an investigation would be beneficial.
I’ve attached an image of the flight path downloaded via AirData visualized on Google Earth.
The aircraft is hovering in the upper left corner.
In my opinion this is typical “VSC” behavior.
Read this thread:
I understood that the issue depends on VSC.
It’s unfortunate, but I’ll stop waypoint flight mode when necessary and shooting.
Thank you for the information.
