Two Colour Light Painting - Heron/Moon and fixing problems
Went out a couple of nights ago to finally run a two colour light painting mission I had originally planned to do much earlier when the temperature was a bit warmer. Ran this one on my Mini 4 Pro. To change the colour of my mini lights I had to use acrylic paint which worked well. I tried using a piece of balloon with an elastic to change the light colour but the heat from the light started to burn the balloon.
When the missions were split from the original mission some parts of both were missing (fixed in post) so I need to look at them again in the hub and see if I can fix them. Also, I need to move both missions back a bit which should reduce the compressed look of the moon. Further, the cool temperatures at night probably contributed to the tape I used to cover the Mini 4 Pro rear lights partially coming off making the green flashing appear in the photo.
Here’s the result and the original mission plan before it was split.
Chris
