I there. I use missions/waypoints feature and I think it would be great to be able to create some template of waypoits, for example a more complex scenario:
- approach a POI with low altitiude, once closer, climb over the POI with gimbal pointing down, then
- climb ober POI to 50m level, then yaw 180 degress then
- descend to low altitiude with gimbal to 0 degress
Once having that mission in the mission hub, you could access it from the mobile app, scale the mission, rotate it and move it they way you want for the current location. That way we could build a library (public/private) of reusable flight paths that could be used in any part of the world.
