Takeoff location pin
I’ve searched this forum and did a web search but found no way to remove the takeoff location pin I added. It’s not that important for the type of mission I’m running just curious if it can be removed.
Currently it can’t be removed as we could not think of a reason why you’d want to remove it after adding it. You can undo it and it can also be dragged to a new position if needed.
Ok. Wanted to make sure I didn’t miss something. As I said it’s not important. Thanks.
