Spiral mission assistance
Hi,
I have a air 2s, and i want to scan a flood light pole. I need a spiral/ circular/ orbit mission for my task.
But when I use litchi hub, and i click orbit or spiral it says it’s not available for DJI drones.
Is there a way to create a mission in litchi so it does this.
Basically i need to define a radius, and it needs to change the elevation and orbit around the object.
You could use the “Spiral Mission Creator for Litchi” from @wesbarris
Don’t forget to click on the green “instructions” bar on the top of the page.
Hi,
Thank you, i saw this but it didn’t work out for me.
The spiral seemed to steep.
How i did it, i generated one spiral using this script ( same height). I exported csv, and manually added circles (spirals) with different height.
When i play it in litchi, it looks perfect, exactly what i needed.
This toolbox that you recommended is really useful
With “Spiral Mission Creator” you have total control over the starting and ending height and how steep the flight is.
