I realize this isn’t actually a Litichi question; but I wonder if anybody here can point me to instructions?
I see various photos and videos of real estate where property boundaries are outlined. I’d like to learn how to do that.
Anybody know how, or have a link to how to? My google-fu has failed me, or I don’t know what terms to search for; all I can find are instructions on how to import a shape file…but I already know how to do that. I want to know how to make an accurate shape file that I can then import.
Those are post-processing photo edits. As you said, not a Litchi question. I have used Photoshop and even Paint to draw lines, but I wouldn’t assume they are accurate.
Import into what? You can import a shape file into Litchi, if you want to create a Waypoint mission … if thats what you are asking.
1st: as you mentioned, Litchi needs a kml, not a shapefile.
2nd: Just keep looking! I found the county assessor’s website that showed the parcels, but there was no way to download or copy the shape or kml. After about a thousand more searches, I finally found a site where I could download the parcel kmls. Whew! Then it was a simple matter of filtering the view to only the parcel I wanted, and then downloading the kml.
So I didn’t end up having to create it, and it’s a good thing, too…the kml I downloaded for a single property is a super odd shape, and has 122 waypoints.
@Andreas_Olsson ,
Will QGis (with a KML plugin) allow you to extract highlighted property lines from a map? Or will you still have to manually draw them, then export the KML?
