Slow mission speed between waypoints
Why is the drone flying so slow when flying a mission ? i set the speeds in the flyhub both to max but between waypoints the max speed the drone flies still is 10 km/h forward and 2-3km/h up and down ?
it would sped it up a lot if the drone would at least fly 30km/h betwwen the waypoints.
Best
Disable obstacle avoidance
What drone and how far between the waypoints
Are you setting the “Max Flight Speed” appropriately?
Capture
yeah those where set to 54 but didn’t set the speed on each waypoint to 54 also, no i found it. thanks for your help and suggestions anyway!
If you want the drone to fly at a constant speed for the duration of the mission you only need to set the “Cruising Speed” in the “Settings” dialog. Then, leave the speed slider for each waypoint all the way to the left which will cause the drone to use that cruising speed.
Capture
i had the mission pre planned with ancient.land . And i guess i forgot to set the speed properly here. So i had to reset the speed on all waypoints.
Hello, I am new to Litchi Hub and need clarification on your response. Are you saying that in order to maintain a constant speed for the whole flight set the waypoint speeds to zero then in the global setting place your speed at the desired level? Is this the only way to do this? Will the program ignore the cruise speed if the speed is set in the waypoints? I just flew a mission I had originally planned in Mission hub that had waypoint speeds all set the same and the drone would speed up between waypoints and slow down at the way points. It was as if the the drone was following the cruise speed and maximum speed and going back and forth in between them. Thanks for the help
Welcome to the forum.
Yes, that is what I am saying.
No, but this is the easiest way to do this.
Yes.
It sounds like you were flying a “straight-line” mission. With the “Path Mode” set to “Straight Lines”, the drone will momentarily stop at each waypoint. If you fly a “Curved Turn” mission, the drone will fly the entire mission at the “Cruising Speed”.
