Can someone lay out the basic steps to get a flight path from litchi hub into my SkyroverXi with screen controller…I’m on windows laptop and I do have an iphone and have installed Lichi Hub bridge. Would much appreciate the help. Regards
Have you followed the steps outlined here?
If so, at what step are you stuck?
Well at square 1 actually..for instance…where do i create the dummy flight mission that is ultimately overwritten with the litchi generated file. In my skyrover ios app on my iphone, or directly in my skyrover screen controller ?
You would create the “dummy” waypoint mission on the device used to fly the SkyRover. Your first post said that you have a “screen controller”. I’m assuming that is something like the DJI RC2. After creating the dummy mission, connect your “screen controller” to your Windows laptop.
If you also have the Litchi app on your iPhone, that would be for another drone. Since the SkyRover does not have an MSDK, it cannot be flown/controlled from a device with an iPhone running Litchi.
I am flying the drone from the SkyroverXi screen controller. I created dummy mission with 2 waypoints and saved it on the controller. When I connect the controller to my laptop i have access to the files on the controller. I can follow this file path to a kmz file "This PC\SKYROVER RC\Internal shared storage\Android\data\com.sky.dronemaster\files\waypoint\56036032-7B20-4AAF-AB57-1C3BA Is this the file I need to overwrite. Thanks in advance for your help
That is the directory containing the kmz file that needs to be replaced.
OK I’m making progress thank you for the help…on Windows 11, in litchi Hub, I go to export and I have a choice for file type…KML or DJI KMZ…which do I use
A KML file is for Google Earth Pro. A DJI KMZ file is for DJI Fly drones or the Skyrover X1.
