whenever i try to change the sharpness setting on my mini 2 it doesn’t change anything.
Almost all settings you set in either DJI FLY or Litchi are stored in the Aircraft itself. So what you set in DJI FLY will still be active in Litchi, and vice versa.
So workaround: Set the desired sharpness in DJI FLY.
There is no way to set sharpness in DJI Fly, and probably the reason it doesn’t work is because the sharpness adjustment is not supported on the mini 2.
yeah you can´t set the contrast in DJI Fly but you can in Litchi. It´s a shame because the sharpness level of the mini 2 is too high
