Rotate and photo
In a fixed position,(waypoint 1) I would like to take a photo, rotate 30 degrees, then take a photo, then rotate thirty degrees and take a photo all the way around for a 360. 20 Photos total. My Mavic Air2s stops after the first photo. I use stay 1 sec, Take photo, stay 1 sec, rotate 30 degrees, stay 1 sec, take photo, stay 1 sec…..I cannot get past the first photo…no rotations. ANY SUGGESTIONS?
The rotate drone action needs an absolute angle.
For example if you do the below it should work:
  1. Take photo
  2. Rotate to 30deg
  3. Take photo
  4. Rotate to 60deg
  5. Take photo
  6. Rotate to 90deg
  7. etc
Remember to set the path mode to straight lines for Air 2S (no curves)
If the problem persists, share a link to your mission (making sure it’s public so we can see it)
