Hello, I was wondering if someone could confirm if the Remote ID function works when using Litchi - The Mavic 2 Pro has RID after the latest Firmware update, it shows up in the Go4 app but I could not confirm that RID works with Litchi… Please help - TYIA!
RID is broadcast from the drone whether you are using DJI Go4, Litchi, or any another app.
Thanks a lot! - I was not able to see it in the drone scanner app - perhaps a glitch - I will check again - tanks!
If you were using the iOS version of Drone Scanner, you won’t see it. The iOS versions of drone detector apps don’t work due to an Apple limitation.
