Restart from waypoint after last completed to allow mission battery changes
Currently when flying long waypoint missions (e.g. mapping), if there is a need to change the battery, you have to memorise the last waypoint completed and then, following battery change, select the correct waypoint to restart at. When you have hundreds of waypoints this can be tricky and time consuming, it would seem like an easy job to offer an option of restarting at the waypoint following the last completed one when starting a mission, or even better to allow battery changes as part of the mission so no restart required - but I can see that would be more involved.
I would echo that request, as I think one of the BIG advantages of Litchi Missions is for 3D Mapping, and I agree with Dave that it’s a faff having to work the current way. I’m new to this forum, so should I assume that Litchi representatives are monitoring this forum and its comments and will respond accordingly in due course?
Thanks
its certainly possible as other 3rd party app that use the same SDK do it
Yes agreed. Some of my missions are 3 or 4 battery changes long and a return option for battery change would be SO helpful. This would also require the feature to log the last grid point and return back to it to continue the mission. This would be a great feature for the Jira board.
I do hope they are listening… Has got my Vote.
Other apps out there do, do this
A very needed improvement is to have a Waypoint counter keep track of the last Waypoint 3 then propose resuming there after a battery change, RTH, mission Pause or whatever. The Resume Mission seems like very simple improvement. I vote for it.
