Request: Gimbal in 2D map mode
The gimbal angle parameter is locked behind the 3D model now, The path following orientation is locked behind 2D map. As far as i can tell this prevents lawnmower patterns with off-nadir gimbal and path following orientation. This was available in the past versions and i would be grateful if it remained available.
Thank you
Next update will allow changing the heading mode in 3D model / 1 pass
Excellent. Thank You! Much safer to have the drone point in the same direction it is travelling.
