Reduce Live Streaming Bandwidth in Litchi App
Hello,
I am using the Litchi app for live streaming from my DJI drone and I want to reduce the bandwidth used for the live stream.
Current setup:
  • Drone: DJI Mini 2 SE
  • App: Litchi
  • Streaming protocol: RTMP
  • Network: Private LTE network
  • Server: RTMP server running on Ubuntu
Currently the live stream from the drone consumes around 3–5 Mbps per user. I want to reduce the bandwidth because the stream needs to be shared with multiple users.
My questions:
  1. Is there any way in the Litchi app to reduce the streaming bitrate?
  2. Can the streaming resolution or FPS be reduced inside the app?
  3. Is it possible to stream a lower bitrate feed directly from the drone?
  4. Are there any recommended settings for low-bandwidth networks?
There is a setting to reduce the bitrate:
RTMP Live Streaming Bitrate : Select a bitrate for RTMP Live streaming. A lower bitrate may help if you have a slow connection.
You can change it between 1, 2 and 3.5Mbps or Auto.
Resolution can only be changed for some drone models, not Mini 2 SE.
ok Can u Please guide how can i reduce bandwidth of Mini2 SE..???
Mini 2 SE is not a supported drone model: Help - Litchi
Hi I have just seen this request, we have a solution that enables the live streaming from as little as 1kbps. If you want to know more have a look at our website
