For the last 3 waypoint missions on my DJI Mini 4 Pro with the RC2 Controller the screen has frozen and the Mission was aborted automatically triggering a „fly-to-home“. The last missions have used between 150-200 waypoints which capture photos at 90 degrees. The mission aborted today after around 30 photos, but yesterday the mission carried on to the end.
Has anyone had similar problems? Could this be controller Problem or a drone problem? The sandisk 256gb SD card was recommend by DJI and new and empty.
Litchi is not compatible with the Mini 4 Pro and 3rd party applications cannot be installed on the RC2. Therefore, it is unlikely that you are using Litchi. Could you provide more information on what you are doing or why you are reporting this to the Litchi forum?
With that many waypoints, it would suggest that you are using an external application to generate this mission. Is it a mapping mission? Perhaps you are creating this mission using another program and then converting it into a KMZ file and importing it to DJI Fly. I have heard reports that the RC and RC2 will be sluggish when missions of that size are imported.
I’ve been using ancient.lands to define the flight paths and waypoints for a mini 2 and then exported the csv and created the KMZ using your Litchi utilities. The first 10 missions have worked fine. but the last few have caused the controller to freeze.
I was thinking it was maybe something someone else has encountered and hoped to find a solution.
Were those first 10 around the same size (150-200 waypoints)? I have heard from a couple people that when they load large missions into the RC2, it becomes sluggish when trying to edit the mission. One person did say that their RC2 crashed when loading a really large mission. I also know of people who successfully fly a 200+ waypoint mission with a DJI RC. I wish I could test this myself but I do not have an RC or RC2 drone.
The first missions were smaller - maybe 50-100 Waypoints. I’ll have to do some more tests. DJI have noticed that my Mini-SD Card was not one of their recommended ones. I had a sandisk Extreme Pro 256 instead of the recommended 64gb. I can’t imagine that this would make a difference though!
Hi Robert8! I was executing a litchi->kmz mission with 192 waypoints on Mini 4 Pro with RC2 and also experienced first very sluggish performance of the controller, then a reboot of the controller and then frozen screen. The drone luckily successfully executed the mission by itself and landed back in the home location, but far from ideal.
Did you manage to find a workflow preventing the RC2 from freezing?
Looking forward to hearing from you - even if you didn’t find a solution. Thank you!
(i’ve got the latest firmware on both RC2 - V06.00.0.200 and drone - V01.00.1000)
