Hi, is it possible to be logged in, on the RC with screen to DJI FLY and litchi with RCN1 at the same time.
The drone will automatically log out of Litchi the instant you log into DJI Fly, and conversely log back into Litchi when Litchi is reopened with the drone powered on.
I use DJI-Go4 to calibrate the compass and IMU before switching over to Litchi for all my flying, without bothering to force-close DJI Go4. I presume the same one-or-the-other-but-not-both ( Exclusive OR) protocol applies to running DJI Fly and Litchi concurrently. That is to say.the drone will connect with whichever but NOT both of the two apps is maximized on the screen of your smart device used for drone flying.
It sounds like you would like to use the DJI RC (with DJI Fly) and the RC-N1 with a phone or a tablet (running Litchi) both connected to a drone at the same time. That will not be possible as only one controller can be paired with the drone at a time.
If what you are trying to do is to view the video feed from two devices simultaneously, you should check out Litchi Vue.
I see what you are saying but not what I meant. if I log on to RC (with Screen) but not turned onm can I log on to RCN1 without logging out of RC ws?
I’m sorry, but what you are trying to describe is not clear. How can you log in if it is not turned on?
The RC-N1 is the controller used with either a phone or a tablet. You don’t actually log into the RC-N1. Instead, you attach a phone or tablet and then run the Litchi app (or DJI Fly) on that phone or tablet. Both Litchi and DJI Fly store your login credentials so that every time you start either app, you are automatically logged in to either your Litchi or DJI account.
If you are asking if you can be logged into your DJI account from several devices at the same time, the answer is “yes”. If you are asking if you can be logged into your Litchi account from several devices at the same time, the answer is “yes”.
