Question about RTK
From @Daniel_Snyder : If I start my Mavic 3E (with RTK), and let it converge in the Pilot 2 App, then switch over to Litchi Pilot, does Litchi Pilot fly using the RTK or does it revert back to regular GNSS? (I do notice the difference in the number of satellites when I am using RTK (30 typically) vs GNSS (20 typically). Hence my question. Thanks.
RTK will not be active in this case. We are working on adding RTK support.
Hello, We are eagerly awaiting some good news on the RTK implementation. Is this a difficult implementation? Is it actively being worked on and do you need an alpha tester? Thanks!
Work on it was paused to make way for other features which took priority. However it’s not forgotten and it’s quite high on the priority list. When ready for testing, it will be released in a Litchi Pilot beta build.
