Problems with saved missions loading in Mission-Hub
Does anyone know what the problem could be?
I have several saved missions in the mission hub.
After I flew the first saved mission with my Dji Mavic 2 and wanted to load the second mission - I always got the error message “could not load mission, waypoint…” and then the rest of the message is unfortunately not visible - even when you click on it.
I then tried it with the other saved mission but exactly the same problem. A restart did not help always after the first mission the same problem when I want to load another saved mission.
@Adi_Eos
It sounds like your device (phone, tablet, etc) was not connected to the internet. Your first mission was already loaded into the device, but you couldnt load a second one … nor could you re-load the first one again.
Thank you. I thought i had connection nur maybe you’re right… Sounds at least very reasonable.
Ill try this. Thank you!
