Hi, I am using a DJI Mavic 2 Zoom. When I am starting a mission, the first waypoint is No. 1. Perfect. But when I stop the mission - to change the battery - and resume the mission from say waypoint 9, there is no way to pick another waypoint to start from. I see the window asking for the starting waypoint, but do not manage to change it. The first waypoint is green, all others are purple. Any Idea?
As a work around I deleted the waypoints 1 to 8 in this case. Hope there is an easier way…
George
If you tap on another purple waypoint, it should select it as starting waypoint
Unfortunately that does not work. Is it a general problem or just mine?
Thanks for the videos, it is the way I tried it, too. But it’s still not working with me. Anyway, a specific problem then.
I will use the work around.
