Phantom 3 Standard -- WAYPOINTS?
I’m a dev so im working with the java SDK sample app.
Every time i try to upload a basic mission, few waypoints, it says “Error: Navigation Mode Not Available”
But i get extremely mixed answers online on if this drone can do missions or not.
Is there a mode i need to switch it into first? GPS? Function mode? Atti?
I’ll literally pay like $100 if someone can help me get missions uploaded to my Phantom 3. Same exact issue with Virtual Stick missions btw.
I see some people on these forums somehow seem to be able to execute litchi missions on the P3 Standard!
And my same uploadAndExecuteMyMission() method works perfectly in my Phantom 4.
For a Phantom 3 Pro the switch has to be in F-mode AND in the DJI GO app enter the “Camera” page, and tap “Mode”, then activate “Multiple Flight Mode”.
Most likely caused by the above (switch 2 & DJI GO).
The Phantom 3 Standard is NOT a VSC-drone (Virtual Stick Commands).
The Phantom 3 Standard IS compatible with Litchi.
Start by reading “Connecting Litchi to your drone” in the “Litchi Online User Guide”:
DJI Download Page:
Awesome thanks so it’s not compatible with VSC but it CAN do waypoint missions?
Are the waypoint missions the same as Phantom 4 (etc) waypoint missions, or are there any special limitations I should note?
And wheres the switch that says “F-Mode” ?
I don’t see one
My Drone is Phantom 3 Standard, which I’ve seen people on here do waypoints with, somehow
Plz help :pray: :palms_up_together: me with this
Bonjour, l’interrupteur que vous cherchez est le S1. Il a 3 positions P, A, F. Le F est celui le plus près de vous. Dans le manuel d’utilisation du drone vous avez la réponse a toutes vos interrogations. Cordialement.
Yes, the Phantom 3 Standard is compatible with Litchi (Read the Online User Guide)
YES
Download the User Manual of the drone and read it, link provided in a previous post.
That link didn’t have any manual for me to download, and i couldn’t find a manual on the site.
My controller also does not have any R - A - F mode switch, did you see the image i uploaded?
I fly waypoint missions on the Phantom 3 Standard using Litchi all the time. The switch in the upper-right of the controller must be switched toward you (the front of the controller).
Here is footage from the city of Baltimore, whose cityscape is the playground of the legendary Dirty Bird, whose flotillas of DJI drones have been flying extremely complex Litchi waypoint missions that are better seen than described.
During the early years of Dirty Bird’s sideline career as a renegade drone pilot, the mystery man cited the Phantom 3 drone as his favorite DJI drone from the standpoint of mission-aloft longevity, thanks to the light weight of the Phantom 3 Standard in comparison to the slightly heavier Phantom 3 variants, namely the Professional, the Advanced.
In the footage below, a pair of Phantom 4’s fly extensive and convoluted Litchi flight paths over Baltimore with precision and timing that have become hallmarks of Dirty Bird’s aerial exploits.
The short answer to the question of whether a Phantom 3 can fly Litchi missions is an emphatic YES. Furthermore and from personal experience, I can attest that a Phantom 3 Standard will fly Litchi waypoint missions covering 6 miles of distance round trip with ease, provided the cruise speed is set for 25mph.
YES it does, open your eyes and READ.
Ok thx sweetheart you in paticular are a gem :smile:
I read the entire 55pg manual, and this part was relevant:
I tried flipping my right hand S1 switch into every position but none get it into F mode (for missions).
All 3 ways i flip it, only goes between these 2 modes. Never Into F mode.
Pos 1 = P-Atti mode
Pos 2 = Atti mode
Pos 3 = P-Atti mode again :cry: :sob:
I activated this, which they say helps. But still can’t get into F mode or upload missions.
This is my Drone btw, i bought it from some guy, are we sure it’s a phantom 3? It flies fine with the app, camera etc all works i just can’t upload a mission
That is indeed a Phantom 3 Standard
That’s because you have insufficient satelites locked (Position- & Function Mode are NOT available when there’s NO GPS lock).
-Enable multiple flight modes in DJI GO
-Set S1 in position 3 (F-mode), wait until the home point has been set (slow flashing green aircraft status indicator).
-Start your waypoint mission.
Ok that’s awesome thank you I’ll try that
Not working,
I took the P3 Standard outside and got 7+ satellites and put it in all possible S1 switch positions, the bottom one gave me F-GPS (function mode??) but then when I connected the DJI sample app to try waypoints, I always still get the “Failed to upload mission, Navigation mode not Available” error.
I’m a programmer and have tried many ways.
The mission verifies & loads, but not UPloads. So it’s a Phantom 3 Standard issue, nothing else. Confirmed
These are some more recent errors.
It’s like my Phantom 3 Standard just can’t do anything autonomous.
My Phantom 4 can do all of these waypoint missions & virtual sticks routes perfectly with no such issues.
WILL LITERALLY PAY $100+ TO ANYONE WHO CAN HELP ME MAKE MY PHANTOM 3 DO ANY OF THIS SUCCESSFULLY
Sweetheart, how is all of this related to litchi?
