Orbit and Spiral:
It would be great if we could configure how many waypoints make up a single rotation. As far as I can tell, it’s currently set to about 33 waypoints per rotation. This way, we could create longer flight plans by reducing the resolution.
The number of waypoint is optimized and dynamically adjusted depending on radius, if you reduce it, you may not get a perfect orbit as we are working with smooth curves which only produce circles with enough waypoints
I see, but perhaps when creating the spiral, we could set the input field to an optimal value and allow for adjustments within certain limits, knowing that such adjustments will result in a deviation from the ideal curve.
can’t even use it with a mini 2 in the new hub
