Not stable connection between dji rc pro and dji mini 3 pro
Hi all, I PLEASE I need some help because the connection between my mini 3 pro and the rc pro is not functioning properly.
In manual mode Litchi is ok, but when I start the mission the connection between the mini 3 pro and the rc pro comes and goes.
AIRCRAFT DISCONNECTED is the message. I have uninstalled Litchi and installed again on the rc pro the file is com.flylitchi.litchipilot.dji_1.0.0_BETA-dji_526.apk but unfortunately still the connections come and go.
On the other hand, with dji fly, the drone fly normally.
thanks a lot
the message AIRCRAFT DISCONNECTED comes and go
Marco
Stessa configurazione, anche il mio sistema uas accusa gli stessi sintomi, risultando quindi impossibile l’utilizzo di flylitchi.litchipilot.dji_1.0.0_BETA-dji_526 in modalità automatica…
Usually when this happens it’s trying to connect back and forth between both the Litchi and DJI Fly app. You must go into the controller settings and force stop the DJI Fly app. Swiping up will not force stop the app. You can turn off automatic startup with the DJI app in those settings so any time you power on the controller it won’t start it.
