Not being able to create a way point mission from kml
I’m trying to create a waypoint mission from a kml file but when I import the file It is added as an overlay on the map instead. On the previous version of the hub I used to import kmls containing polylines and each vertex used to be treated as a waypoint automatically. I also noticed that the options to export the missions are limited now, some options as export as csv or 3d path are missing. Are there any options to be able to complete this task the same way as in the old hub those functions were very usefull.
KML files are treated as overlays and importing KML to actual waypoints is not currently supported. If you’re plotting in google earth to import in Litchi Hub, why not use the built-in google earth view in Litchi Hub straight away?
Export to CSV is not currently supported.
Export to 3D Path is not necessary since you can use the built-in google earth view, that said you can also export to KML which includes the 3D Path that the old Hub would export.
