Haven’t used this controller in awhile and changes to missions on Hub are not updating on the Smart Controller app.
Litchi version 4.28.0-a
Tried logging out and back in again but no luck.
You didn’t say, so I have to ask: Is your Smart Controller connected to the network? There are only two requirements for missions to sync from the Mission Hub to the device running Litchi:
You can also try the “Check and sync license” option in the Litchi app settings.
I access the Hub using a laptop and logged in with same credentials on laptop and Smart Controller Litchi app.
Toggled Sync Local Missions in the app on the Smart Controller several times.
“Check and sync license” just did this and get Licensed successfully checked and synced!
Still getting the old version of the mission on the Smart Controller ![]()
Oh and yes the Smart Controller has a good internet connection and can browse the web with Lightning OK
Go 4 is force closed
OK more wierdness ![]()
On the laptop I open the mission in question and save as OldName New and it syncs OK ![]()
BUT ![]()
I see in missions in the Hub the mission in question has a duplicate mission “OldName” “OldName”
I notice several NOT recently modified missions in the hub have a duplicate with the same mission name ie. “Amistad 90 Bridge” “Amistad 90 Bridge”.
The duplication appears on numerous random old missions but not all.
There seems to be some corruption in my mission files on the hub!
I’ll try another browser.
Different browser also shows duplicate mission names???
Not seeing the duplicate names in the app in the Smart Controller.
That is really strange. Have you been using both the new and old versions of the Mission Hub? I’m sorry but I have no idea what is causing your duplications. I am not experiencing that.
If there was a way to replicate the duplication problem, I could try following your steps to see if it happens to me.
I wondered if using the new beta hub was related. Yes I have briefly checked out the new beta hub.
It is possible. There are some features in the new Mission Hub that are not supported in the old Mission Hub. Perhaps, opening an old mission in the new Mission Hub, setting one of these new features (like drone type), and saving causes a duplicate mission to be created. I have not done this myself.
I do not see duplicates in the beta hub. What I’ve done in the beta hub is create folders and moved existing missions into the folders(likely where the conflict occurs?)
Only other thing I’ve done in the beta hub is preview an unrelated mission using Google Earth.
I just tested moving the 2 newly created copies of existing missions into folders in the beta hub and they were NOT duplicated in the old hub.
The duplications in the old hub seem to be random affecting missions I’ve not used/edited or even loaded in over a year in most cases.
Deleting one of the duplicates leaves the original so I can clean out all duplicates and stay out of the beta for now.
Good. I have tried putting saved missions into folders and modifying the same mission using Mission Hub v1 and v2 and back to v1. I have not been able to replicate a mission as you have described.
Perhaps some browser caching issue. I’ll post if I learn anything more. Simply deleting the duplicates seems to solve my issue. Thanks for the suggestions. ![]()
